Volvo S60R Test in der car&driver.com
WiWa
Volvo S60R AWD
C/D TEST RESULTS
ACCELERATION (Seconds)
Zero to 30 mph: 1.9
40 mph: 2.8
50 mph: 4.3
60 mph: 5.5
70 mph: 7.4
80 mph: 9.0
90 mph: 11.0
100 mph: 13.9
110 mph: 16.7
120 mph: 20.2
130 mph: 25.6
140 mph: 31.4
Street start, 5-60 mph: 6.5
Top-gear acceleration, 30-50 mph: 13.2
50-70 mph: 8.7
Standing 1/4-mile: 14.0 sec @ 101 mph
Top speed (governor limited): 148 mph
BRAKING
70-0 mph @ impending lockup: 168 ft
Fade: none light moderate heavy
HANDLING
Roadholding, 300-ft-dia skidpad: 0.88 g
Understeer: minimal moderate excessive
FUEL ECONOMY
EPA city driving: 18 mpg
EPA highway driving: 25 mpg
C/D-observed: 20 mpg
INTERIOR SOUND LEVEL
Idle: 45 dBA
Full-throttle acceleration: 76 dBA
70-mph cruising: 70 dBA
VOLVO S60R AWD
Vehicle type: front-engine, 4-wheel-drive, 5-passenger,4-door sedan
Price as tested: $41,550
Price and option breakdown: base Volvo S60R (includes $685 freight), $37,510; leather seats, $1495; in-dash 4-CD changer, $1200; 18-inch wheels and tires, $995; Climate package (consists of heated front seats and rain-sensing wipers), $350
Major standard accessories: power steering, windows, seats, and locks; A/C; cruise control; tilting and telescoping steering wheel; rear defroster
Sound system: Volvo AM/FM-stereo radio/CD changer, 10 speakers
ENGINE
Type: turbocharged and intercooled 5-in-line, aluminum block and head
Bore x stroke: 3.27 x 3.66 in, 83.0 x 93.2mm
Displacement: 154 cu in, 2521cc
Compression ratio: 8.5:1
Engine-control system: Bosch Motronic ME7.01 with port fuel injection
Emissions controls: 3-way catalytic converter, feedback air-fuel-ratio control
Turbocharger: KKK
Waste gate: integral
Maximum boost pressure: 14.7 psi
Valve gear: belt-driven double overhead cams, 4 valves per cylinder, hydraulic lifters, continuously variable intake- and exhaust-valve timing
Power (SAE net): 300 bhp @ 5500 rpm
Torque (SAE net): 295 lb-ft @ 1950 rpm
Redline: 6500 rpm
DRIVETRAIN
Transmission: 6-speed manual
Final-drive ratio: 3.77:1, electronic limited slip
Gear ... Ratio ... Mph/1000 rpm ... Max. test speed
I ... 3.38 ... 5.5 ... 36 mph (6500 rpm)
II ... 2.05 ... 9.1 ... 59 mph (6500 rpm)
III ... 1.43 ... 13.1 ... 85 mph (6500 rpm)
IV ... 1.09 ... 17.1 ... 111 mph (6500 rpm)
V ... 0.87 ... 21.5 ... 140 mph (6500 rpm)
VI ... 0.70 ... 26.7 ... 148 mph (5550 rpm)
DIMENSIONS AND CAPACITIES
Wheelbase: 107.0 in
Track, F/R: 61.3/60.7 in
Length: 181.3 in
Width: 71.0 in
Height: 55.0 in
Ground clearance: 5.2 in
Curb weight: 3717 lb
Weight distribution, F/R: 56.9/43.1%
Fuel capacity: 18.5 gal
Oil capacity: 6.0 qt
Water capacity: 8.4 qt
CHASSIS/BODY
Type: unit construction
Body material: welded steel stampings
INTERIOR
SAE volume, front seat: 54 cu ft
rear seat: 41 cu ft
luggage space: 14 cu ft
Front seats: bucket
Seat adjustments: fore and aft, seatback angle, front height, rear height, lumbar support
Restraint systems, front: manual 3-point belts; driver and passenger front, side, and curtain airbags
rear: manual 3-point belts, outboard curtain airbags
General comfort: poor fair good excellent
Fore-and-aft support: poor fair good excellent
Lateral support: poor fair good excellent
SUSPENSION
F: ind, strut located by a control arm, coil springs, anti-roll bar
R: ind; 1 lower control arm, 1 trailing link, 1 lateral link, and 1 toe-control link per side; coil springs; anti-roll bar
STEERING
Type: rack-and-pinion, power-assisted
Turns lock-to-lock: 2.5
Turning circle curb-to-curb: 42.7 ft
BRAKES
F: 12.9 x 1.3-in vented disc
R: 12.9 x 1.1-in vented disc
Power assist: vacuum with anti-lock control
WHEELS AND TIRES
Wheel size: 8.0 x 18 in
Wheel type: cast aluminum
Tires: Pirelli P Zero Rosso, 235/40ZR-18 95Y
Test inflation pressures, F/R: 33/34 psi
Link dazu hier: http://www.caranddriver.com/article.asp?section_id=3&article_id=6848&page_number=1
Habe leider den Test noch nicht gelesen. Erstmal hier reingestellt.
