NISSAN R390
Hellhammer
hat jmd. ein paar daten(leistung,ausstattung & preis) über den nissan r390 ??
wenn ja,per pn melden...
Make Nissan
Year 1996
Engine Location Mid
Drive Type Rear Wheel
Weight 2420 lbs | 1097.7 kg.
Gears 6
Transmission Type manual
Final Drive NA
Price $1,000,000.00
Skidpad NA
Body Material NA
Steering Rack and Pinion
Engine
Cylinders 8
Engine Configuration V
Aspiration/Induction Twin-turbocharged
Displacement 3495 cc | 213.3 cu in. | 3.5 L.
Valves 32. 4 valves per cylinder.
Valvetrain NA
Horsepower 404.8 Kw / 550 BHP @ 6800 RPM
Torque 637.3 Nm / 470 Ft-lbs @ 4400 RPM
Bore NA
Stroke NA
Compression Ratio NA
Dimensions | Chassis | Body
Length 186 in | 4724.4 mm. | 4.7 m.
Width 79 in | 2006.6 mm. | 2.0 m.
Height 45 in | 1143.0 mm. | 1.1 m.
Wheelbase 107 in | 2717.8 mm. | 2.7 m.
Front Track NA
Rear Track NA
Ground Clearance NA
Cargo Volume NA
Passenger Volume NA
Interior Volume NA
Bed Length NA
Seating Capacity NA
Performance
0-60 mph 3.9 sec
1/4 Mile 11.9
Top Speed NA
Na reicht das?? :D
Wieviele davon verkauft wurden weiß kein Mensch aber dre mindestens!!
Zwei blaue und ein roter!!
Nismo
