the power of forced induction.
djfux69
I've had that download on my computer for awhile now. It actually shows the true nature of the eclipse.
It can also handle a good bit more than that, upto 800hp.
lets not forget that the "power" of the 4g63 was also to crank walk. it was a nifty little trcik that made the cranck slide side to side in its journals, causing it to warp and piston 2&3 to slam into the head. mitsu didnt cover this under warrenty. also the tranfer cases on the awd models tended to lock up while driving. not a good thing to be driving down the road at 60 and your rear wheels lock up, also not covered under warrenty. if you saw that your Xcase was leaking before it broke, mitsu would give you a new gasket. how thoughtful of them.
