POI bei der Drift-/Performancebox
MasterMike
hat schonmal wer versucht bei seiner Driftbox POI´s einzufügen?
Muss dafür ein extra Verzeichniss angelegt werden oder wie geht das?
In der Anleitung steht es nicht beschrieben.
Points of Interest (POI)
In the Speed Display Mode, there is a ‘Points of Interest’ (POI) facility that can be used to
indicate when the vehicle is near to a pre-determined geographical position. This option is
active whenever the inserted SD card contains a valid.ov2 POI file. A common use of POI
files is to store the location of safety cameras, but custom POI files can also be created to
give locations of any other points that might be useful for testing purposes.
DriftBox will beep and display an icon on-screen whenever the vehicle moves within 250
meters of a POI, unless the vehicle is moving away from the POI.
The Points of Interest feature will only function if the correct POI files are present on the
SD card. These files can be downloaded from various websites such as
www.poihandler.com. The only file format recognised by DriftBox is the .ov2 type.
In order to display an icon when near a POI, the SD card must also contain a monochrome
bitmap file no larger that 22 x 22 pixels with the same name as the corresponding .ov2 file.
For instance: if a POI file named Filling_Stations.ov2 is present on the card and you wish
to display a corresponding image when approaching one of the points of interest, the
image file must be called Filling_Stations.bmp.
ok, das erklärt die Funktion :)
Ich habe die Dateien jetzt erstmal in das Hauptverzeichnis gelegt, mal sehen was passiert. Werde es heute testen.
Das war uebrigens aus der offiziellen Anleitung... ;)
Hab die P-Box verkauft, kann's daher nicht testen.
hab ich mir gedacht, aber die us Anleitung, oder? Weil in der für Deutschland steht es so nicht drin wegen nicht 100% Rechtslage oder so ähnlich :)
