Engine smoothness
GIR
I found this article on BMW850.de and thought I'd share it with you guyz.
The number of cylinders is not the primary reason for engine smoothness, another important factor is the way the engine is constructed, if it's an inline-, V- or boxer-engine. Those concepts will be discussed here.
The One-Cylinder Engine (general)
A one cylinder four-stroke engine delivers power only in the working/combustion cycle (the compression cycle even needs power) and therefore, measured by the rotation of the crankshaft, only every 720°. To smoothen this rather jerky power delivery one needs a flywheel (which lessens the engine's responsiveness) - or more cylinders.
An increase in cylinders does mainly mean more working cycles per crankshaft rotation and therefore a smoother power delivery.
With four cylinders there is a working cycle every 720° / 4 = 180°, with eight every 90° and with twelve even every 60° (3: 240°, 5: 144°, 6: 120°, 10: 72°).
But now there are the vibrations caused by the moving parts inside the engine. I will restrict this to pistons and connecting rods in order to keep it simple and because they are the main source of vibrations.
Rods and pistons move up and down without counterweights and of course there is movement to the side as well, but that only for the rods which don't weigh so much.
The crankshaft of a one cylinder engine.
For simplification the counterweights
for the crank pins have been left out.
The Inline-Two Engine
A two-cylinder engine has a working cycle every 360°, which means that both pistons have to be in the same position and move in same direction all the time. The vibrations therefore are twice as bad as with a one-cylinder engine because the forces of both cyliders add up. This design has the most vibrations and is therefore the less used one.
The crankshaft of an inline-two engine.
The Inline-Three Engine
Every 240° there is a working cycle. The frontal view shows that no matter at what angle the crankshaft is, the center of gravity stays in the middle always so that no vibrations are generated. Almost. The image and the calculation do not take the third dimension into account. The pistons are not arranged in a plane but in line. While there is an upward force being generated by piston and connecting rod in the frontmost cylinder, there is a downward force in the rear one. Because these forces act on different ends of the engine, there is end-to-end vibration, around the center cylinder.
Crankshaft of a inline three cylinder engine.
Frontal view of crankshaft.
The Inline-Four Engine
Now things get complicated. Although it seems that a four cylinder engine is free of vibration, it is not.
An inline four engine fires every 180° which means that always two pistons are in the same position and move in the same direction. Because of the symmetrical arrangement there is no end-to-end vibration as with the three cylinder engine (piston 1 and 4 plus 2 and 3 are pairs).
The problem is the vertival movement. At first glance it seems that the forces generated by the first piston are cancelled by the second and the forces of the third are cancelled by the fourth. But that is not the case!
As you can see in the picture, pistons which are moving up, are moving at different speeds than pistons that are moving down. So there are vibrations again which have to be cancelled by balancer shafts.
The crankshaft of an inline four engine.
Forces generated by pistons and rods which are moving up and
down do not cancel themselves but result in 'second order forces'.
The Inline-Five Engine
This type of engine is mentionned only to be complete, because it is not neceessary for understanding engine smoothness. Except vibrations from end to end (like a three cylinder engine) a five cylinder engine runs smoothly.
The crankshaft of an inline five engine.
The Inline-Six Engine
As you can see an inline six engine consists basically of two mirrored three cylinder engines. That results in two sorts of vibrations (around cylinder #2 and #5) which cancel themselves. So there isn't even end-to-end vibration.
Because the crankshaft is identical to the one of a three cylinder, only twice as long and with twice as much pistons, here as well is no change of the center of gravity and no forces are generated, neither horizontal nor vertical ones. That is the reason why inline six cylinder engines run so smoothly.
The crankshaft of an inline six engine.
The V6-Engine
The V6 is a special kind of V-engine. It is normally the case that two pistons, one for the left and one for the right cylinder bank, share a crank pin. In a V6 the crank pins have to be splitted and shifted in order to avoid vibration between banks.
There are two kinds of V6 engines with different V-angles in use, 60° and 90°. The 90°-V6 has a 30° crank pin shift (see picture), the 60°-V6 60° shift.
Just as the three cylinder engines, a V6 generates end-to-end vibration, so a balancer shaft is needed. Thus V6-engines are inferior to inline six engines concerning smoothness, despite having the same number of cylinders.
So why use V engines? Although twice as much camshafts are needed, the higher friction, the lack of smoothness and the higher production cost, the V6 uses much less space, which helps saving costs in other places and allows front wheel drive (which saves further costs).
Crankshaft of a 90°-V6 with 30° pin shift.
The V8-Engine
There are two types of V8s which differ by crankshaft. The V-angle is always 90°. The two types are called cross-plane (crank pins at a 90° angle) and flat-plane (crank pins at 180°). V8 engines have the advantage of not being in need of split crank pins in order to avoid vibrations between cylinder banks.
With a cross-plane V8, however, the last cylinder is not in the same position as the first, so there is end-to-end vibration again. That can be solved by adding counterweights to the crankshaft which cancel the forced created by the pistons. That is possible only in a V-engine with a V-angle of 90° and without splitted crank pins. These counterweights, fitted to an inline engine, would move to the side when the piston moves up or down and therefore generate additional vibration. But in a 90° V-engine there are pistons on the same crank pin which move exactly into the opposite directions of the counterweights (because of the bank angle) and their forces can be cancelled. Cross-plane V8s are therefore running quite smooth but because of the heavier crankshaft they are not as revvy.
Flat-plane V8 engines do not have those problems. They are also more responsive because of less rotational inertia. That increases maximum rpm and top-end power. In addition the crank case can be smaller which lowers the center of gravity.
But why are the flat-plane engines used in sports cars only if there are so many advantages? That's because of the crankshaft itself, the disadvantage of the flat-plane type. As you can see, the arrangement of crank pins is identical to a four cylinder engine which means there are also vibrations, only stronger, as basically two inline-four engines are running simultaneously. In sports cars those vibrations are reduced by using very lightweight pistons and connecting rods. That is of course expensive and because ride quality isn't too important either, the rough characteristics (compared to a cross-plane) are tolerated. Because of the crankshaft, the sound of such an engine is the one of two four cylinder engines. A (typical american) cross-plane burbling cannot be achieved.
The crankshaft of a cross-plane V8-engine.
The crankshaft of a flat-plane V8-engine.
The V12 Engine
The V12 is said to be the most sophisticated engine design, being free of vibrations and running smoothly. But so does an inline six. Now what is the difference between those two concepts concerning smoothness, as even the crankshafts look alike?
Let us return to the one-cylinder. It was said there, that an engine's power delivery occurs in 'jerks', every time a combustion takes place. And that is the secret of a V12: the smoothness is increased by more combustions per crankshaft revolution.
The crankshaft of a V12 engine.
Boxer-Engines
In boxer engines the pistons are not aligned upright or in V-shape, but lie horizontally opposed. This type of engine not only achieves an extraordinary low center of gravity but also runs perfectly smooth and free of vibrations - regardless of number of cylinders.
As you can see in the following picture, a pair of pistons are not only always in the same position but also move with the same speed - only into different directions so that all vibrations are cancelled.
A boxer-engine runs always smoothly.
Thanks, very informative and worth printing out. :)
i showed it to my redneck freind. He said first it was too many damn words, and then said it was total BS, because his V8 vibrated and straight engines are stupid.
My freinds, when you wonder what is standing in the way of american manufacturers modernizing, it is their consumer base.
I never understood why the flat engine is not more popular in cars. To me it is the perfect car engine, smooth, torquey, superior cooling features, lower center of gravity. The best reason for flat engines is the simplicity of building a whole engine family, F2, F4, F6, F8, F10, F12, no worries about bank angles, crankshafts and balancers. No compromises. Try doing that with Vees.
If I had to design a perfect family of cars, I'd use a front flat engine, RWD format. Something like a 3.0L F6, 4.0L F8, 5.0L F10 would be perfect for a compact/midsize/large car lineup.
excellent information! thanks GIR! i really want to see more advances with boxers and rotaries.
boxers have their downfalls. They aren't as great as some make them out to be. The lubrication system requires scavaging pumps, they are ungodfully wide, and i personally feel an inline six to be smoother than my flat six.
I think the size is an issue though. Look under the hood of a subaru, those flat engines hardly fit in there.
The BMW I6 is one of the smoothest examples of the type. Try the Jeep Wrangler, definatly not in the same class. It maybe Porsche is just not making the most of it, from a smoothness point of view.
Subarus are exceptionally narrow cars to begin with. If Porsche can fit a 3.6L F6 into my 911, then a 3.0L F6 should fit wider track cars like BMW.
Jeep's I6 is not the same class - or even close.
The thing is, the F6 sits totally ahead of the rear axle in boxster, totally behind in 911. In a subaru, which is front engine, or something like a BMW 3 Series, you take up a lot of suspension room by putting an engine that wide in there, otherise you have to mount the engine higher up (defeating the lower polar center of intirtia). The I6 bimmmer uses is exceptionally narrow, and allows more room for whee turn, suspension, steering, and drive components, if you forced an F6 in there, something would have to give. There is a reason only 2 automakers use the boxer engine.
I understand your point. My thinking is either to place the engine behind the front axle line (superb balance), or like you said raise the engine a few inches and move the transmission under it (ala Ferrari 512).
Hell in a world of BMW imitations, I don't want to be accused of flattery.
Yeah, but F512TR was exorently expensive and castratingly painful to work on. For specific layouts, the flat engine definately has benefits, but in the standard front engine or front midship layout, they are limited.
Hallo GIR,
It occured to me if you want optimum smoothness you can get rid of poppet valves altogether. Some sort of rotary valve combined with a flat engine would be perfect. The Cross rotary sits on the side of the cylinders, so even flat engines can be narrow enough to fit anywhere you want it to.
a rotary valve would be most ideal, if you think about it, poppets aren't neccesary, a came lobe intermitently covering and uncovering an opening would be very good. More efficient too because of a reduction in reciprocating mass.
a car with a great flat engine was the Ferrari testarossa. It had a flat12 that could make 390hp
Think about it this way, if flat 6's were better engines fro Bimmers that the I6's, then they would have been used. BMW engineers know better than all of us combined.
