audi s4
audiboy17
i was wondeirng how much boost the stock 2000 audi s4 can run when i put on a boost controller. How much psi can i run. thanks for the help
someone delete this post, i cant get it to go away. the second one is the one i wanted to submit, i dont know how 2 came up.
you cant run a boost controller on the s4. it has an electronically controlled external wastegate that no matter how high you turn up the boost, it will only allow the stock setting, which i beleive is 9psi. you need to buy a chip, goapr.com they have good stuf with chips starting around $600. the 93 octane setting will push boost up to 14.5 safely with 328hp and 368tq. dont buy the boost controller, and if you already did, send it back
stock boost is 9.1psi on the 2.7TT. it is also true that boost is linked into the main ECU - and is wastegate controlled. A chip is the most efficient way to increase boost. The turbos are not capable of over a little better than 14, but that is a large increase. If you want more pressure than that, get ready for some work.
