New Zonda Roadster at Geneva Auto Show
a007apl
· Carbon fibre body
· 7.3-litre
· 555 hp and 750 Nm
ITALIAN PAGANI, THE brand behind Zonda C12 S will unveil a new car, the Zonda Roadster, at the Geneva Auto Show, opening March 6th. To be produced in a strictly limited edition of 40 completely made-to-measure cars, the Zonda Roadster will once again crystallize Pagani's philosophy: marry the most exotic technology - such as the never-seen-before carbon carbon/carbon textile removable roof - to the loving care of the "artigiano" handwork, to produce "Una Macchina con Anima".
The new Zonda Roadster, has been designed around truly innovative technology ideas, and with a special attention to safety - a key issue in the "SuperConvertibles" segment, and a constant preoccupation of the manufacturer - as its technical specs show:
- the new carbon fibre central chassis structure reaches the highest structural rigidity level available in the segment, 18.000 Nm/mm in torsional rigidity, 9.000 Nm/mm in flexional rigidity, for a dry weight of 1280 Kg;
- the roll bar, elliptical in section, is built out of carbon and chrome-molybdene alloy and is linked to the aft section of the chassis through a finely hand worked Ergal element;
- the full-carbon body shows a new engine hood configuration, and a new rear hood design where two NACA air vents work as air extractors;
- the 7.3l Mercedes Benz AMG engine transmits its 555HP and 750Nm power through the ABS/Traction Control safety systems already used in the Zonda S;
- the wheels are forged in aluminum and the 255/35/19 and 345/35/19 tires have been specially developed for the Zonda by Michelin, adding to the car’s unique styling and technology.
____________________
FACTS
· Pagani Zonda Roadster
· World Premier at the coming Geneva Motor Show
· 7.3-litre Mercedes-Benz powerplant
· 555 hp and 750 Nm
· 255/35/19 and 345/35/19
WOW! What a beatifull piece of machinery and so powerfull. Too bad I can't afford it :(
Maybe one day if I work hard enough...
I like the Jet engines on top of the dash. And I also like Roxana (I hope she comes with the car!)!.
I think the Zonda looks pretty wicked in Yellow, but I'd love to see it in other colors or color-combos. It also needs a bit more HP. That's my ¢2.
