Saleen Mustang
Arty25
what do you mean, there have been and still are a number of very different saleen mustangs being built.
right, the new one, that makes it really easy.
Hey, how about that new Ford, you know the new one, the new ford.
Speaking of stats, does anyone know anything about that new GM car? Thats' a sweet ass ride!
I think Arty may be refering to the 2004 Saleen SR. Heres' a rundown ...
* Engine ...
4.6 liter Saleen Centrifugal Supercharged OHV V8.
Power : 505hp. @ 5,400 - 500lb.ft. @ 3,500
Compression ratio : 8.2:1 ... Bore & Stroke : 4.00" x 3.50"
* Other stuff ...
Sequential electronic fuel injection
65 mm throttle body
Saleen upper/lower manifold
80 mm air sensor
36lb. per hr. fuel injectors
Hydraulic roller camshaft and lifters
Forged aluminum pistons and heads
Ceramic coated headers
2.5" stainless steel 4-way catalytic high flow exhaust
High flow fuel pump ( no shit? )
Premium fuel calibration
High performance radiator.
* Drivetrain ...
Quick ratio 6-speed manual transmission
Ford 9" limited slip differential
Custom balanced driveshaft
* Suspension ...
Front : Saleen Racecraft independant uneven length wishbone with N2 triple adjustable shocks and adjustable swaybar.
Rear : 3-link live axle with swaybar. Performance enhancements : Unibody construction with roll cage and suspension rienforcement, power assisted rack & pinion steering.
* Brakes ...
Power 4-wheel ABS disc brakes with integrated cooling ducts,
Front : 14.4" metallic discs
Rear : 13.0" metallic discs - 4-pot calipers all around.
* Wheels ...
Saleen five spoke alloys. 18" x 10" front - 18" x 11" rear.
* Tires ...
Pirelli PZeros' - P285/30/ZR18 front - P335/30/ZR18 rear.
Yadda yadda yadda ...
* Performance ...
1/4 mi... 11.8 @ 124.0
0-60 ..... 4.0
Grip ..... 1.09g
60-0 ..... 98ft.
MSRP ... $158,000 - $175,000 ... Depending on the kind of mood Saleen is in apparently. A Saleen Racecraft IRS is available. The whole thing sounds like a huge rip off to me. Get a Ford GT instead.
ford doesn't make a 4.6L OHV engine, they make a 4.6L SOHC and DOHC engine, but not OHV. Saleen makes a few cobras with 5.8L ford OHV engines.
And yes, it is a rip off. You could get the S281 with IRS for, oh, 70k. I could see that, but 170? I think i'd sooner just go get something a bit more upmarket, like a ferrari, hmm Ford's Horsey car, or the original horsey car, hmm, i'll go for the italian stalian at that price.
it appears a misprint, that car uses fords overhead cam 4.6L. All engines used in saleens come from stock ford blocks.
Hallo Arty25,
schau doch mal hier zum Thema Zubehör für US Cars (Anzeige)? Eventuell gibt es dort etwas Passendes.
