Airco problem ? ?
Mechanic
When I turn my airco on, I will work fine for a minute of 5. Then it go off.
If I stop the car, turn it off en start again the airco will work again for a minute off 5. Airco has just had a full service.
My car is a E300 TD model 210 with a full auto airco system.
Anybody can help me ? ? :-?
:-? Thank a lot.
First off all check your settings, maybe they reset the airco while maintenancing it. Sound like a computer problem to me.
I have check all the settings and read the memory of the airco ecu. No faillures. Is it possible that the engine ecu cut off the airco for a reason ?
The ECU of the engine isn't connected with the your airco, the COMAND unit is however, it's the central processing unit in your car. If you the say cut off's are timed then it suggest there's something wrong with onboard computers, take it back tot the dealer and see what they say.
