How do I read Ferrari VIN numbers?
Lamberko
Quelle:
Ferrari SpA VIN Equipment Codes
Many Ferrari owners are interested in deciphering the 17-digit Vehicle Identification Number that is inscribed on their Ferrari. The information from this FAQ is based on an article on the subject written by Lloyd W. Shaw.
The Federal Motor Vehicle Theft Law Enforcement Act of 1984 became law on October 25, 1984. The standard applies to both major parts and all motor vehicles produced during the 1987 model year and all sequential models produced thereafter.
The 17-digit Vehicle Identification Number must be inscribed on the engine, transmission, both front fenders, hood, both doors, both bumpers, both rear quarter panels and the decklid or hatchback (whichever is present). The VIN taken from the stated locations shall provide a true description of the vehicle to which it is assigned.
All Ferrari models have the VIN embossed on a metal plate affixed to the top of steering column. An example of a Ferrari VIN is shown below, and the subsequent information and chart explains how to decode the label. The chart covers VINs starting in 1983.
Z F F X D 2 1 A 9 G 0 0 3 8 0 9 9
1st digit = country of origin
The first digit identifies the vehicle's country of origin. Italy's letter is "Z," therefore, all Ferrari VINs will begin with the letter "Z".
Z = Italy
2nd + 3rd digit = marque / manufacturer
The second and third digits identify the marque and manufacturer. To date, Ferrari SpA has been assigned and used only two codes
DF = the Dino
FF = the Ferrari marques manufactured by Ferrari SpA.
The Dino marque has not been produced since 1980, therefore "FF" will appear in the second and third place digits of all Ferrari VINs, unless you are looking at a Dino.
4th digit = Engine
With only 26 letters available, it was necessary to recycle some of the letters. Always consider the entire 17 digit VIN to determine the type of engine, especially the sixth and seventh digits
A = 308 2-valve injected (U.S.A.model)
B = 308 2-valve carb wet sump (Euro.model)
C = 308 2-valve carb dry sump (Euro.model) + 328 European
D = 512 Boxer carbureted
E = 400 V-12 fuel injected
F = 308 Australia + 348 U.S.A. / Japan
G = 308 2-valve carbureted USA/Japan + F40 European
H = 308 2-valve injected European
J = 512 Boxer injected
K = 208 Turbocharged European + 348 European
L = 308 4-valve European + 512 TR European
M = 308 4-valve U.S.A. 1993 + F40 U.S.A.
P = F355 + 288 GTO
R = 348 U.S.A.
S = Testarossa U.S.A./Japan + 456
T = Testarossa European
U = 308 4-valve U.S.A. ( 1984-1985 )
V = 512M
W = 328 European
X = 328 U.S.A. / Japan
Y = 412 V-12
Z = 550 Maranello
5th digit = Safety system
A front 3-point inertia belts
B front 3-point inertia belts; rear 3-point non-inertia belts
C front 3-point inertia belts; rear 2-point inertia belts
D front 3-point inertia belts; rear 3-point inertia belts
G passive restraint system
P front 3-point inertia belts and air bags; rear inertia belts
M passive restraint system
N automatic passive restraint system
R front 3-point inertia belts and air bags
6th + 7th digits = vehicle model / body type
01 308 GT4 (ZDF) & 308 GTBi (ZFF)
02 308 GTBi
03 308 GTB
04 308 GTS
05 512 BB
06 400i automatic
07 400i 5-speed
08 Mondial
09 512BBi
10 208 Turbo (B)
11 208 Turbo (S)
12 308 GTB Quattrovalvole
13 308 GTS Quattrovalvole
14 Mondial Quattrovalvole Coupe
15 Mondial Quattrovalvole Cabriolet
16 288GTO
17 Testarossa
19 328 GTB
20 328 GTS
21 3.2 Mondial Coupe
24 412 automatic
25 412 5-speed
26 3.2 Mondial Cabriolet
27 GTB Turbo
32 Mondial T Coupe
33 Mondial T Cabriolet
34 F40
35 348 B
36 348 S
40 F512M
41 F355 Berlinetta
42 F355GTS
43 348 Spider
44 456 GT
48 F355 Spider
49 550 Maranello
8th digit = market
A USA (left-hand drive)
B Europe (left-hand drive)
C UK (right-hand drive)
D Australia (right-hand drive)
J other left-hand drive
S other left-hand drive
T Middle East (left-hand drive)
9th digit = check digit (used by law enforcement agencies)
The ninth digit is a check digit used by law enforcement agencies to ensure that the VIN is valid. By using a very complicated formula involving the entire VIN, a law enforcement officer can determine if the VIN is correct for the vehicle being checked. Occasionally a letter, rather than a number, will appear in this space, but it will usually be a number between 1 and 9. In some cases, this number will be a zero on vehicles that were built for markets outside of the United States.
10th digit = Is used to designate the year model for vehicles produced for the U.S. market.
A = 1980
B = 1981
C = 1982
D = 1983
E = 1984
F = 1985
G = 1986
H = 1987
I = NOT USED
J = 1988
K = 1989
L = 1990
M = 1991
N = 1992
O = NOT USED
P = 1993
Q = NOT USED
R = 1994
S = 1995
T = 1996
11th digit = assembly plant
The eleventh digit is used to designate the company's plant location where the vehicle was produced. This digit should always be zero, since all Ferraris are produced in Maranello, Italy.
0 = Maranello, Italy
12th --> 17th digit = production number
The twelfth through seventeenth digits are production numbers in sequential order. This number should allow you to determine when the vehicle was produced in the production run.
When purchasing a used, Ferrari one should carefully compare the VIN against the different vehicle compoments.
If the VIN indicates that the vehicle should have a fuel injected 4-valve motor, while in fact it has a carbureted 2-valve motor, you can safely assume that the motor has been changed out in this vehicle. This would adversely affect the overall value of the vehicle and your future investment.
It is very important that the VIN is correctly shown on all documents, (registration title, insurance papers, etc.) concerning your vehicle.
The data on this page was obtained in part from the 59th annual edition of the National Automobile Theft Bureau handbook for Law Enforcement and an article which appeared in the Ferrari Market Letter.
Also mei 348 hat ZFFUA und ist schon mal kein 308:???:
Ist halt ´n Ferrari. :D
Bei der VIN gibt´s immer wieder Probleme mit der richtigen Zuordnung:
(Ferrari-Chat)
How many digits shoud the vin number of a 1978 ferrari 308 GTS have. I know that in 1980 the us cars required to have 17 digits. I only found to have 11 digits with mine. Does that sound right..
17 digits isn't enough, The early '80s Euro 17 digit VINS had a series of zeros in the fields that the US used for model year and a check digit.
This causes problems. Since an 'O' is the US code for the 1984 model year, most Euros end up getting registered as '84s even tho they may have been built much earlier.
I was lucky, when I bought my car I was able to get a FAX from FNA stating that my car was built in October '82. MA still insisted in registering it as an '83 model year car tho.
The dealer wouldn't push the issue since the emissioins test cut-off is 83 & earlier & if it had been a US make it would have been an '83.
Everytime I give someone my VIN & they type it into a computer I start grinning. Sure enough it's gonna get rejected. Then they tell me my VIN is wrong, it's failing the check & the model year is '84, not '83.....
My 78 GTS is F106AS*23825* Build date on car March 1978 - Heritage Certificate date 01/03/78 1, March, 1978
When I bought the car the title had just the chassis number 23835. When I went to register it in MS the state said that that number had already been used and they could issue me a number and a new serial plate to attach to the car with STC23825 STC= State Tax Commision. I did a little research and found the stamped number on the frame rail on the right rear in the engine compartment with the full VIN. That is what we used to register the car.
The 17 digit VINs started in 1980. I tried to Carfax mine and found out that you can't Carfax pre 1980 cars because they don't have the long VIN.
Die Antwort auf alle Fragen ist 42.
(F355 GTS) X-)
(F355 GTS) X-)
Falsch!!O:-)
41:D :D :D
(Ferrari-Chat)
und ich wollt dir für den Eingangspost grad ein Päckle grüne Bobbels geben:wink:
Aber jetzt musst du die Verwirrung die du angerichtet hast,
erst mal bereinigen:D
Dann schau mr nochmalX-)
Hier eine aktuelle Übersicht der VIN-Identifikation entliehen von der Ferrari Seite von Edvar van Daalen www.red-headed.com :
VIN: VEHICLE IDENTIFICATION NUMBER
Since 1980, all Ferraris are equiped with a VIN, a uniform 17-digit Vehicle Identification Number. It was first introduced on US models, as it was required for all cars in the US made after January 1st 1980. Other markets soon followed.*
The VIN can be found in several places, but on all models (except the Enzo Ferrari) it can be found on a plate on top of the steering column. Depending on the model and the market, the VIN can also be found stamped on a plate or in the chassis in the engine room, or on plates in the doors.
The overview published on this page explains each digit of the VIN. It was made with help from Gerald Roush (Ferrari Market Letter) and other Ferrari-spotters. Certain information is from official documents, but not everything. So, please note that this overview may contain errors and that it isn't complete. Corrections and additions will always be appreciated.
1st - 3rd DIGIT Nation of Origin, Make
ZFF Italy, Ferrari, Ferrari
ZDF Italy, Dino, Ferrari (only used on a very small number of Dino 308 GT4s!)
4th DIGIT Engine
A 308 GTB/Si, Mondial 8 US version
A Testarossa* Euro version, type F113B
A 612 Scaglietti 2004 - 2007
B * 408 Prototype
B ** 308 GTB/S Euro version, wet sump
B ** Dino 308 GT4
B 575 M Maranello
C ** 308 GTB/S Euro version, dry sump
C 328 GTB/S, Mondial 3.2 (Cabr) Swiss, 1987-1989 with catalyst
C Enzo Ferrari
D 512 BB
D Challenge Stradale
E 400i
E * PPG Prototype for 348 engine
E F430
F 348 tb/s, Mondial T (Cabr) US, 1989-1990, Motronic 2.5
F 599 GTB Fiorano
G *** 308 GTB/S US version
G F40 Euro version
G Superamerica
H 308 GTBi/Si, Mondial 8 Euro version
H FXX
J 512 BBi
J 612 Scaglietti* 2007- ....
K 208 GTB/S Turbo Italian version
K 348 tb/s, Mondial T (Cabr) Euro version
K 430 Scuderia
L 308 GTB/S QV, Mondial QV (Cabr) Euro version
L 512 TR
M 308 GTB/S QV, Mondial QV (Cabr) US version, 1983 (230 HP)
M F40 US version
N 308 GTBi/Si, Mondial 8 Australian version
P 288 GTO
P F355 series 1994-1995, Motronic 2.7
R 308 GTB/S QV, Mondial QV (Cabr) Australian version
R 348 series, Mondial T (Cabr) US, 1991-1995, Motronic 2.7
S Testarossa US version
S 456 GT(A) 1992-1996, Motronic 2.7
T Testarossa Euro version, type F113 A
T F50
U 308 GTB/S QV, Mondial QV (Cabr) US version, 1984-1985 (235 HP)
U 348 GTB/S, 348 Spider Euro version
V F512 M
W 328 GTB/S, Mondial 3.2 (Cabr) Euro version
W 456 (M) GT(A) 1997-200x, Motronic 5.2
X 328 GTB/S, Mondial 3.2 (Cabr) US version
X F355 series 1996-1999, Motronic 5.2
Y 412
Y 360 Modena, 360 Spider
Z GTB/GTS Turbo Italian version
Z 550 Maranello, 550 Barchetta
Remark: the "markets" listed above, are only for a rough indication.
*: Only used on a few prototypes
**: Only used on a small number of late-production cars
***: Although listed in official documents, it was probably never used
5th DIGIT Restraint system
A 3-point inertia belts with auto retractors for front
B 3-point inertia belts with auto retractors for front plus 3-point non-inertia belts for rear
C 3-point inertia belts with auto retractors for front plus 2-point inertia belts for rear
D 3-point inertia belts with auto retractors for front plus 3-point inertia belts for rear
E [on several 2+2 for Australian market; no airbag?]
G Passive restraint system (= Active belts with manual lap belts)
J [on Euro F40]
K [on >1990 Mondial T Cabriolet US versions]
L Air bags, manual seat belts plus UCRA* in the rear seats
M Passive restraint system (Canada)
N Automatic passive restraint system
P Air bags with 3-point inertia belts for front and inertia belts for rear
R Air bags, manual seat belts and force limiter
S Air bags, manual seat belts plus UCRA*
T Air bags, manual seats belts with pretensioners
U Air bags, manual seats belts with pretensioners plus UCRA**
V Air bags, manual seats belts with pretensioners and force limiter plus UCRA**
W Air bags, manual seats belts and force limiter plus UCRA*
X [on racecars and prototypes]
Y [on 612 Scaglietti]
Z [on Euro Enzo Ferrari and F430]
* UCRA = Universal Child Restraint Anchorage system
6th + 7th DIGIT Model
01 308 GTBi (ZFF, Ferrari), Dino 308 GT4 (ZDF, Dino)
02 308 GTSi
03 ** 308 GTB
04 ** 308 GTS
05 512 BB
06 400i Automatic
07 400i 5-speed
08 Mondial 8
09 512 BBi
10 208 GTB Turbo
11 208 GTS Turbo
12 308 GTB QV
13 308 GTS QV
14 Mondial QV Coupe
15 Mondial QV Cabriolet
16 288 GTO
17 Testarossa
18 * 308 Convertible
19 328 GTB
20 328 GTS
21 Mondial 3.2 Coupe
22 unknown
23 unknown
24 412 Automatic
25 412 5-speed
26 Mondial 3.2 Cabriolet
27 GTB Turbo
28 GTS Turbo
29 * 328 Convertible
30 * Testarossa Spider
31 * 412 Cabriolet
32 Mondial T Coupe
34 F40
35 348 tb, 348 GTB, 348 tb SS
36 348 ts, 348 GTS, 348 ts SS
37 * 408
38 unknown
39 unknown
40 512 TR, F512 M
41 F355 Berlinetta, 355 F1 Berlinetta
42 F355 GTS, 355 F1 GTS
43 348 Spider
44 456 GT, 456 M GT
45 unknown
46 F50
47 unknown
48 F355 Spider, 355 F1 Spider
49 550 Maranello
50 456 GTA, 456 M GTA
51 360 Modena, 360 Modena F1
52 550 Barchetta Pininfarina
53 360 Spider, 360 Spider F1
54 612 Scaglietti
55 575 M Maranello, 575 M Maranello F1
56 Enzo Ferrari
57 Challenge Stradale
58 F430
59 F430 Spider
60 599 GTB Fiorano
61 Superamerica
62 FXX
63 F430 Challenge
64 430 Scuderia
8th DIGIT Market
A Left-Hand Drive North America or Middle East (>2000)
B Left-Hand Drive Europe
C Right-Hand Drive UK
D Right-Hand Drive Australia
J / JAP / JPN Left-Hand Drive Japan
JAP: approx. 1980 - 1994 (with "AP" as the 9th and 10th digit)
JPN: approx. 1994 - 2000 (with "PN" as the 9th and 10th digit)
J: approx. 1997 - present* (with "00" as the 9th and 10th digit)
L Left-Hand Drive Latin-America
S Left-Hand Drive Switzerland*or Sweden
T Left-Hand Drive Middle East (<2000)
X Other, for one-offs, prototypes and race cars
9th DIGIT Check digit
A or P Specific Japanese models (for more info, see 8th digit)
0 - 9 and X USA, Middle East (>2000), Latin America(>2006)
(a specific calculation, see below)
0 Other markets
The check digit of the VIN appears in the 9th position of US versions and provides a way to verify the validity of all of the other characters in positions 1-8 and 10-17. The check digit is calculated by carrying out the following mathematical computation.
(1) Assign to each number in the VIN its actual mathematical value and assign to each letter the value specified in following Table:*
A = 1 G = 7 N = 5 V = 5
B = 2 H = 8 P = 7 W = 6
C = 3 J = 1 R = 9 X = 7
D = 4 K = 2 S = 2 Y = 8
E = 5 L = 3 T = 3 Z = 9
F = 6 M = 4 U = 4
(2) Multiply the assigned value for each VIN character in the VIN by the Position weight factor specified in the following Table:*
VIN position Weight factor VIN position Weight factor
1st 8 10th 9
2nd 7 11th 8
3rd 6 12th 7
4th 5 13th 6
5th 4 14th 5
6th 3 15th 4
7th 2 16th 3
8th 10 17th 2
9th to be calculated
(3) Add the resulting products and divide this total by 11.
(4) The numerical remainder is the check digit. If the remainder is 10 the letter 'X' shall be used to designate the check digit. The correct numeric remainder, zero through nine (0-9) or the letter 'X' shall appear in the VIN position nine.
10th DIGIT Model Year
The "Model Year" was only used on US and Middle East versions:*
A 1980
B 1981
C 1982
D 1983
E 1984
F 1985
G 1986
H 1987
J 1988
K 1989
L 1990
M 1991
N 1992
P 1993
R 1994
S 1995
T 1996
V 1997
W 1998
X 1999
Y 2000
1 2001
2 2002
3 2003
4 2004
5 2005
6 2006
7 2007
8 2008
For other markets:
P or N Specific Japanese models (for more info, see 8th digit)
0 All other markets (incl. late Japanese models)
11th DIGIT Assembly plant
0 Maranello
12th - 17th DIGIT Serialnumber
The VIN was introduced near s/n 30xxx. Until s/n 75000 only odd serialnumbers were used. After 75000 both odd and even numbers were used.
The VIN was also used on a small number of (late production) Dino 308 GT4s. Those VINs start with ZDFBB01 and end with even numbers near 15xxx.
Das passt schon eher alles:-))! Demnach hab ich auch tatsächlich einen 348 GTB.
Nur woanders stand schon das ZFFUA auch beinhaltet das es eine Schweizer ausführung ist:???:
Watt denn nu:-(((°
Watt denn nu:-(((°
Es ist eine schweizer (oder schwedische) Version wenn nach ZFFUA dann ein S steht, wo sonst eigentlich für deutsche (europäische) ein B steht.
8th DIGIT Market
Hallo Lamberko,
Würde ich ja gerne....aber ich steige momentan selbst nicht mehr durch....:D:-(((° :-(((° :-(((°
Vielleicht könnte ein User mit viel Freizeit diesen ganzen Krempel mal vernünftig zusammenfassen?
:oops:
