F430 Gt(2)
F40org
gesehen bei fastdrive.org
ENGINE
Type: Ferrari F136, 8 cylinders with V 90° layout
Capacity: 3.998,6 cm³
Materials: Aluminium alloy engine block and cylinder heads
Intake system: Air induction limited by two restrictors Æ 28.8 mm
Timing system: 4 camshafts (2 per each cylinder head), 4 valves per cylinder
Injection and ignition: Magneti Marelli engine management
Fuel: Unleaded 102 RON, 88 MON
POWER TRAIN
Type: 6 speed + reverse, sequential control
Differential: self-locking, adjustable by blades
Clutch: 5”1/2 syntherized three discs
CHASSIS AND BODYWORK
Chassis: aluminium monocoque, steel safety cage (per FIA rules), engine and gearbox
stiffly fitted to the chassis
Steering system: rack and pinion system, power steering
Suspensions: independent wheels, overlapped aluminium triangular wishbones, adjustable
shock absorbers, adjustable anti-roll bar
Brake system: Brembo, steel discs Æ 380 × 32 mm (front) Æ 332 × 32 mm (rear), 6 pistons
(front) and 4 pistons (rear) calipers, adjustable brake balance
Bodywork materials: carbon / kevlar / nomex / aluminium
Aerodynamic devices: adjustable single profile rear wing, carbon floor with rear diffuser
Weight: 1100 kg (all the liquids at the standard level, without fuel and driver)
und hier gab es schon vor einiger Zeit Bilder vom GT.
http://www.carpassion.com/de/forum/ferrari-355-360-430/19665-f-430-challenge-5.html
